Ana içeriğe geç
Lenovo G780 Fan Replacement
Neye ihtiyacın var
  1. Lenovo G780 Fan Replacement, Battery: adım 1, 2 resimden 1. Lenovo G780 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Fan Replacement: adım 2, 1 resimden 1.
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Fan Replacement, Fan: adım 3, 3 resimden 1. Lenovo G780 Fan Replacement, Fan: adım 3, 3 resimden 2. Lenovo G780 Fan Replacement, Fan: adım 3, 3 resimden 3.
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Fan Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Fan Replacement: adım 5, 2 resimden 1. Lenovo G780 Fan Replacement: adım 5, 2 resimden 2.
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 790
