Ana içeriğe geç
Lenovo G780 Heat Sink Replacement
Neye ihtiyacın var
  1. Lenovo G780 Heat Sink Replacement, Battery: adım 1, 2 resimden 1. Lenovo G780 Heat Sink Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Heat Sink Replacement: adım 2, 1 resimden 1.
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Heat Sink Replacement, Fan: adım 3, 3 resimden 1. Lenovo G780 Heat Sink Replacement, Fan: adım 3, 3 resimden 2. Lenovo G780 Heat Sink Replacement, Fan: adım 3, 3 resimden 3.
    • Remove the six 9 mm screws from the back panel with a Phillips #0 screwdriver.
    • Save these screws.
    • Remove the back plate.
  4. Lenovo G780 Heat Sink Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to detach the fan by removing the two black 9 mm screws and the single silver 4 mm screw that is securing it to the motherboard.
  5. Lenovo G780 Heat Sink Replacement: adım 5, 2 resimden 1. Lenovo G780 Heat Sink Replacement: adım 5, 2 resimden 2.
    • Carefully disconnect the fan cable from its socket on the motherboard.
    • The fan should now be completely free from the laptop motherboard and chassis.
  6. Lenovo G780 Heat Sink Replacement, Heat Sink: adım 6, 3 resimden 1. Lenovo G780 Heat Sink Replacement, Heat Sink: adım 6, 3 resimden 2. Lenovo G780 Heat Sink Replacement, Heat Sink: adım 6, 3 resimden 3.
    • Remove three 7mm spring loaded screws using a Phillips #1 screwdriver.
    • Remove these two 4 mm screws using a Phillips #1 screwdriver.
  7. Lenovo G780 Heat Sink Replacement: adım 7, 2 resimden 1. Lenovo G780 Heat Sink Replacement: adım 7, 2 resimden 2.
    • The heat sink needs to be rotated counter-clockwise slightly to allow space for removal.
Sonuç
Riley Griffin
316 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Henning Spring 2019 IUPUI, Team S2-G4, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 590
