Ana içeriğe geç
Lenovo G780 Screen Replacement
Neye ihtiyacın var
  1. Lenovo G780 Screen Replacement, Battery: adım 1, 2 resimden 1. Lenovo G780 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the computer.
    • Slide the battery-lock switch on the bottom of the laptop to the unlocked position.
  2. Lenovo G780 Screen Replacement: adım 2, 1 resimden 1.
    • Hold the battery release switch in the unlocked position and remove the battery.
  3. Lenovo G780 Screen Replacement, Screen: adım 3, 2 resimden 1. Lenovo G780 Screen Replacement, Screen: adım 3, 2 resimden 2.
    • Using the metal spudger, peel back the adhesive-backed bumpers on the bottom left and right corners of the screen.
  4. Lenovo G780 Screen Replacement: adım 4, 3 resimden 1. Lenovo G780 Screen Replacement: adım 4, 3 resimden 2. Lenovo G780 Screen Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove both 5.5mm screws from the corners of the screen.
  5. Lenovo G780 Screen Replacement: adım 5, 3 resimden 1. Lenovo G780 Screen Replacement: adım 5, 3 resimden 2. Lenovo G780 Screen Replacement: adım 5, 3 resimden 3.
    • Using an iFixit opening tool, start prying on the top face cover on the screen by applying pressure near the bottom of the screen.
    • Once the face cover has started to come away from the screen, begin pulling away with both hands until the whole face cover has been removed from the screen.
    • Be careful not to break the thin plastic cover.
  6. Lenovo G780 Screen Replacement: adım 6, 3 resimden 1. Lenovo G780 Screen Replacement: adım 6, 3 resimden 2. Lenovo G780 Screen Replacement: adım 6, 3 resimden 3.
    • Remove the four 8.5mm screws on the corners of the screen that connect the screen frame to the back cover.
  7. Lenovo G780 Screen Replacement: adım 7, 2 resimden 1. Lenovo G780 Screen Replacement: adım 7, 2 resimden 2.
    • With the back cover being removed from the screen frame, the back cover can be set aside.
  8. Lenovo G780 Screen Replacement: adım 8, 3 resimden 1. Lenovo G780 Screen Replacement: adım 8, 3 resimden 2. Lenovo G780 Screen Replacement: adım 8, 3 resimden 3.
    • Carefully remove the clear adhesive tape holding the cable down, being careful not to damage the small wires under the tape.
    • Once the tape has been removed, the ribbon connector will pull away from the back of screen.
  9. Lenovo G780 Screen Replacement: adım 9, 3 resimden 1. Lenovo G780 Screen Replacement: adım 9, 3 resimden 2. Lenovo G780 Screen Replacement: adım 9, 3 resimden 3.
    • Remove the eight, 3mm screws around the screen frame. There will be four on each side of the screen frame.
    • With the screws removed the screen will be free to be lifted away from the screen frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Riley Griffin
316 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Henning Spring 2019 IUPUI, Team S2-G4, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 974
