Giriş
Bring you two-in-one tablet back to life with a new hard drive.
This guide will provide step-by-step instructions on how to detach the rear panel, which is designed to prevent damage to interior components. This guide will also provide you instructions on how to remove and mount a new hard drive.
Neye ihtiyacın var
Flip the device so the rear case is facing upward.
With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
Using your Philips head screw driver with the number 1 head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
2 farklı kişi bu kılavuzu tamamladı.
