Ana içeriğe geç
Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Stand Base: adım 1, 1 resimden 1.
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
    No need to remove stand. Back still comes off easily.
    Marvin - Yanıt
  3. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Back Cover: adım 3, 1 resimden 1.
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 4, 3 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 4, 3 resimden 2. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 4, 3 resimden 3.
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 5, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 5, 2 resimden 2.
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Unscrew the four screws that secure the hard drive enclosure.
  7. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 7, 1 resimden 1.
    • Unplug the SATA cable. Lift to remove the hard drive enclosure.
  8. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 8, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 8, 2 resimden 2.
    • Unscrew the four screws that hold hard drive enclosure to the hard drive, located on the side of the enclosure.
  9. Lenovo IdeaCentre AIO 510S-23ISU Hard Drive Replacement: adım 9, 1 resimden 1.
    • Lift the hard drive up to remove it from the enclosure.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Jackson Blake
1.119 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G3
4 Üyeler
5 Yorum
you have been busy!!!!! Noticed the solutions , etc. below and that is impressive. chaosone7 @gmail.com
Bobby Kincannon - Yanıt
It’s nice and easy to get there, unfortunately the board was fried lol.
Charles Allen - Yanıt
Can I replace the hard drive with a 1TB SATA III 6Gb/s 4-bit QLC V-NAND Flash 1GB Cache 2.5" Solid State Drive - Samsung QVO
Donna Briggs - Yanıt
The hard drive in this should be a 2.5” drive, so the replacement you listed should work
Jackson Blake -
Do you have a better suggestion
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 72
Her zaman: 15,955
