Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
Remove the two screws on the bottom of the computer, one on each side.
Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
Remove the 5 screws that secure the EMI cover.
Remove the cover.
Locate the power switch board and the tan colored tab on it holding the blue and white ribbon cable down.
Pull the tab towards the blue and white ribbon cable to open it. Pull the cable out of the power switch board.
Slide the power switch cable out of its slot in the direction shown, making sure to lift up the end carefully.
Bir başkası bu kılavuzu tamamladı.
