Ana içeriğe geç
Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, Stand Base: adım 1, 1 resimden 1.
    • Turn off the computer, unplug all cables, and let it cool down. Lay the computer flat on its screen.
    • Make sure that the work surface is flat and has nothing sharp on it.
  2. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 2, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 2, 2 resimden 2.
    • Remove the monitor stand screw in the bottom of the stand, and remove the stand completely.
  3. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, Back Cover: adım 3, 1 resimden 1.
    • Remove the two screws on the bottom of the computer, one on each side.
  4. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 4, 3 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 4, 3 resimden 2. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 4, 3 resimden 3.
    • Locate the slot on the right side of the computer next to the screw hole. Use a plastic opening tool or spudger to pry off the rear cover. (Don’t be afraid to use a little force.)
  5. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 5, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 5, 2 resimden 2.
    • Once it has been separated, lift to remove.
  6. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, Arm Stand: adım 6, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, Arm Stand: adım 6, 2 resimden 2.
    • Remove the four screws that secure the arm stand.
  7. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 7, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement: adım 7, 2 resimden 2.
    • Lift up to remove the arm stand.
  8. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, EMI Cover: adım 8, 3 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, EMI Cover: adım 8, 3 resimden 2. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, EMI Cover: adım 8, 3 resimden 3.
    • Remove the 5 screws that secure the EMI cover.
    • Remove the cover.
  9. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, RAM/Memory: adım 9, 2 resimden 1. Lenovo IdeaCentre AIO 510S-23ISU RAM/Memory Replacement, RAM/Memory: adım 9, 2 resimden 2.
    • Push the two retaining clips away from the RAM sticks.
    • Gently lift up the free side of the RAM module and then pull out of the slot.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jackson Blake
1.119 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G3, Banghart Winter 2018 Cal Poly, Team S16-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 3,675
