Ana içeriğe geç
Lenovo IdeaCentre K410 CPU Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre K410 CPU Fan Replacement, Side Panel: adım 1, 1 resimden 1.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Fan Replacement: adım 2, 1 resimden 1.
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Fan Replacement, CPU Fan: adım 3, 1 resimden 1.
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 CPU Fan Replacement: adım 4, 1 resimden 1.
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
Sonuç
Timothy Grebe
1.652 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G39
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 2,358
