Ana içeriğe geç
Lenovo IdeaCentre K410 CPU Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre K410 CPU Replacement, Side Panel: adım 1, 1 resimden 1.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Replacement: adım 2, 1 resimden 1.
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Replacement, CPU Fan: adım 3, 1 resimden 1.
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
  4. Lenovo IdeaCentre K410 CPU Replacement: adım 4, 1 resimden 1.
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 CPU Replacement, Heat Sink: adım 5, 1 resimden 1.
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
  6. Lenovo IdeaCentre K410 CPU Replacement, CPU: adım 6, 2 resimden 1. Lenovo IdeaCentre K410 CPU Replacement, CPU: adım 6, 2 resimden 2.
    • Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
    • Remove the 11 mm screw using a Torx #20 screwdriver.
    • Remove the cover and remove the CPU by gently pulling upward.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Timothy Grebe
1.652 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G39
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Why would you remove the fan and the CPU fixation bracket when you could just remove the heatsink by unscrewing it and then lift up the bracket lever...
alphaLONE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 50
Her zaman: 4,098
