Ana içeriğe geç
Lenovo IdeaCentre K410 Power Supply Unit Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Side Panel: adım 1, 1 resimden 1.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 2, 1 resimden 1.
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: adım 3, 2 resimden 1. Lenovo IdeaCentre K410 Power Supply Unit Replacement, Power Supply Unit: adım 3, 2 resimden 2.
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  4. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 4, 3 resimden 1. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 4, 3 resimden 2. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 4, 3 resimden 3.
    • Unplug all cords attached to the optical drive and hard drive.
  5. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  6. Lenovo IdeaCentre K410 Power Supply Unit Replacement: adım 6, 1 resimden 1.
    • Remove the power supply unit by pulling away from the screw side and then out.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Timothy Grebe
1.652 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G39
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 4,525
