Ana içeriğe geç
Lenovo IdeaCentre K410 RAM Module Replacement
Neye ihtiyacın var
  1. Lenovo IdeaCentre K410 RAM Module Replacement, Side Panel: adım 1, 1 resimden 1.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 RAM Module Replacement: adım 2, 1 resimden 1.
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 RAM Module Replacement, RAM Module: adım 3, 1 resimden 1.
    • Push down on the white clips on both sides of the memory module to release it.
    • Gently pull up on the memory module to remove it from the unit.
Sonuç
When inserting the memory module, make sure that the notch on it aligns correctly with the key on the memory connector. Push the module straight down into the connector until the retaining clips close.
2 farklı kişi bu kılavuzu tamamladı.
Timothy Grebe
1.652 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G39
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
sounds very hard to replace a ram “sarcastically“
you probley can replace a ram if you know what ram is so
remliv - Yanıt
But it is still good to have guides on everything
im glad that ifixit exists
remliv - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,573
