Ana içeriğe geç
Lenovo IdeaPad 100s-14IBR Speaker Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 100s-14IBR Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 3, 1 resimden 1.
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
    • Remove the six 4mm Phillips #00 screws.
    • Remove the battery using the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 4, 2 resimden 2.
    • Unplug the speakers from the motherboard.
    • Remove the two 4mm PH00 screws from the metal shield on the trackpad.
    • Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
  5. Lenovo IdeaPad 100s-14IBR Speaker Replacement: adım 5, 1 resimden 1.
    • Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
Sonuç
Bin Feng
256 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 402
