Ana içeriğe geç
Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement, USB/Headphones Jack: adım 1, 1 resimden 1.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 3, 1 resimden 1.
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 4, 1 resimden 1.
    • Remove the three 4mm PH00 screws.
    • Unplug the ribbon wire connected to the USB/Headphone Jack PCB by lifting the black plastic tab holding the ribbon cable down.
    • Be extra careful not to bend the ribbon cable too much as it is fragile.
  5. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad 100s-14IBR USB/Headphones Jack Replacement: adım 5, 2 resimden 2.
    • Lift the USB/Headphone Jack PCB off of the board gently and put it to the side.
Sonuç
Mohammed Younis
421 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 852
