Ana içeriğe geç
Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 3, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 3, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 3, 3 resimden 3.
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 4, 3 resimden 3.
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Battery Replacement: adım 5, 1 resimden 1.
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 6, 3 resimden 3.
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Hard Disk Drive Replacement: adım 7, 1 resimden 1.
    • Remove the four 4 mm Phillips #0 mounting screws attaching the caddy to the frame.
  8. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently remove the caddy away from the motherboard.
    • If you are removing an already existing HDD, unplug the component along with the caddy and remove the four screws mounting the caddy to the HDD.
  9. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Speaker Replacement: adım 9, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Speaker Replacement: adım 9, 2 resimden 2.
    • Detach the speaker wire from the motherboard.
  10. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 10, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 10, 2 resimden 2.
    • Gently pull upwards on the speaker assembly to remove it from the case.
  11. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: adım 11, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: adım 11, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement, Motherboard Replacement: adım 11, 3 resimden 3.
    • Unlock the ZIF connector and remove the wire connected at the bottom of the motherboard.
    • For the wires with the blue plastic, you must undo the clip before pulling out the wire.
  12. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 12, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 12, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 12, 3 resimden 3.
    • Disconnect the wires attached on the "left" side.
    • Use the spudger to unlock the clip to remove the blue ribbon cable.
  13. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 13, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 13, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 13, 3 resimden 3.
    • Unlock the ZIF connector at the top-left of the motherboard.
    • Remove the ribbon cable.
  14. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 14, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 14, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the single 4 mm Philips #0 screw from the Wi-Fi card.
    • Slide the Wi-Fi card out of the socket.
  15. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 15, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 15, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 15, 3 resimden 3.
    • Unlock the remaining ZIF connector with a spudger.
  16. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 16, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 16, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 16, 3 resimden 3.
    • Disconnect the fan's wire from the motherboard.
    • Remove the four 3 mm Philips #0 screws joining the heatsink to the motherboard
    • Follow the number order when re-installing.
    • Then, remove the three 5 mm Philips #0 screws holding the fan assembly to the frame.
    • Remove the fan and heatsink.
  17. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 17, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 17, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 17, 3 resimden 3.
    • Once everything has been disconnected from the motherboard, remove the six 3 mm Philips #0 mounting screws from the motherboard.
    • There is normally one screw under a sticker at the "bottom" (shown in the picture).
  18. Lenovo IdeaPad 110 Touch-15ACL Motherboard Replacement: adım 18, 1 resimden 1.
    • This is what the frame should look like once everything is removed.
Sonuç
Clark Beuckman
544 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-3, Hunter Spring 2022 Clemson, Team 2-3, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G3
5 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
A general tip: when reassembling not all holes take in a screw even if they look that way. Some holes will get filled when you screw in the screws attaching the back panel, or if there are several layers of stuff attached the screw will go in on another level. But how to know where to put a screw in? Of course you can study the back panel or the other layers to see where the screws go and compare to the screw holes inside but there is an easier way. In almost all the circuit boards there will be a small triangle printed right next to a hole that takes a screw on that particular level. If there are several holes next to each other, examine the printed triangle. There is always one "corner" of the triangle pointing right at the hole where you are supposed to put a screw in. Some of you guys already know this, but as these guides are read by newcomers looking for easy instructions and tips I'm sure not all do. I figured this out by myself and it made my life a lot easier. No more screwing aroung in vain :D
Pertti Kotipalo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 26
Her zaman: 560
