Ana içeriğe geç
Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 3, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 3, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 3, 3 resimden 3.
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 4, 3 resimden 3.
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Battery Replacement: adım 5, 1 resimden 1.
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 6, 3 resimden 3.
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement, Speaker Replacement: adım 7, 2 resimden 2.
    • Detach the speaker wire from the motherboard.
  8. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad 110 Touch-15ACL Speaker Replacement: adım 8, 2 resimden 2.
    • Gently pull upwards on the speaker assembly to remove it from the case.
Sonuç
Clark Beuckman
544 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-3, Hunter Spring 2022 Clemson, Team 2-3, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G3
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 141
