Ana içeriğe geç
Lenovo IdeaPad 110-15IBR Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: adım 1, 2 resimden 1. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: adım 1, 2 resimden 2.
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Remove the thirteen 9 mm Phillips #1screws.
    • Pull out the DVD drive and unscrew the final 3 wide-head screws holding the back in place.
  2. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove the back: adım 2, 1 resimden 1.
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  3. Lenovo IdeaPad 110-15IBR Battery Replacement: adım 3, 1 resimden 1.
    • Remove the two 9 mm Phillips #1 screws holding the battery.
  4. Lenovo IdeaPad 110-15IBR Battery Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad 110-15IBR Battery Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad 110-15IBR Battery Replacement: adım 4, 3 resimden 3.
    • Disconnect the battery cable connector from mother board.
    • Remove battery from device.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Saddam Alsinai
669 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 üyesi
UWT-LINER-F17S3G4
4 Üyeler
14 adet Kılavuz yazıldı
23 Yorum
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
Clarey Ryan - Yanıt
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Daniel Jansen - Yanıt
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
charlie.bansj - Yanıt
Easy to follow
Hugo Jhuboo - Yanıt
I unscrew everything but to open it, it gets stuck in the middle….. i am afraid to pull hard…..
djerro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 44
Son 30 gün: 212
Her zaman: 46,802
