Ana içeriğe geç
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: adım 1, 2 resimden 1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: adım 1, 2 resimden 2.
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 3, 2 resimden 2.
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 4, 2 resimden 2.
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove hard drive from housing.
Sonuç
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14 farklı kişi bu kılavuzu tamamladı.
Saddam Alsinai
669 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 üyesi
UWT-LINER-F17S3G4
4 Üyeler
14 adet Kılavuz yazıldı
3 Yorum
Unplug or remove battery first?
Chris Quirke - Yanıt
Hard disk size?
Mohamad Mustakim - Yanıt
you do not need to unplug or remove the battery
Holden Phillips - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 19,911
