Ana içeriğe geç
Lenovo IdeaPad 110-15ISK Upper Case Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip the IdeaPad bottom side up.
    • Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
    • Flip the computer back to top facing.
  2. Lenovo IdeaPad 110-15ISK Upper Case Replacement: adım 2, 1 resimden 1.
    • Open the lid.
    • Use the plastic opening tool to pry the keyboard up and away from the bottom assembly.
  3. Lenovo IdeaPad 110-15ISK Upper Case Replacement: adım 3, 1 resimden 1.
    • Next disconnect the keyboard cable by using the tip of the spudger or your finger to lightly push out the ribbon from the contact port.
    • Completely remove the keyboard from the bottom assembly.
    • Unlock the ZIF conector before pulling the cable out
  4. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Optical Drive: adım 5, 1 resimden 1.
    • Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
  5. Lenovo IdeaPad 110-15ISK Upper Case Replacement: adım 6, 1 resimden 1.
    • Flip the laptop to its back and the optical drive is located at the top left corner.
    • Remove the optical CD DVD drive by lightly pulling it out of the assembly.
  6. Lenovo IdeaPad 110-15ISK Upper Case Replacement, Upper Case: adım 7, 1 resimden 1.
    • Place the laptop bottom facing up.
    • Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
  7. Lenovo IdeaPad 110-15ISK Upper Case Replacement: adım 8, 1 resimden 1.
    • Separate the top case from the bottom using a plastic opening tool.
    • Continue prying the top and bottom case from each other all around the perimeter of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler
597 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Rose Fall 2018 UW Tacoma, Team S1-G5, Rose Fall 2018 üyesi
UWT-ROSE-F18S1G5
4 Üyeler
39 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 2,415
