Ana içeriğe geç
Lenovo IdeaPad 110-17IKB Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 110-17IKB Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 3, 2 resimden 2.
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad 110-17IKB Fan Replacement: adım 4, 3 resimden 3.
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: adım 5, 2 resimden 1. Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unscrew the four 6 mm Phillips #0 screws that secure the fan.
    • Push the white fan connector directly out of its port using tweezers or a pry tool.
    • Lift the fan up and out of the chassis.
Sonuç
Cameron Mounce
668 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Pee Fall 2023 Gateway, Team 1-3, Pee Fall 2023 üyesi
GCC-PEE-F23S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 63
