Ana içeriğe geç
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 3-15IGL05 SSD Replacement: adım 2, 2 resimden 2.
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad 3-15IGL05 SSD Replacement: adım 3, 2 resimden 2.
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: adım 4, 1 resimden 1.
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
Sonuç
Matthew Frederic
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 88
Her zaman: 3,424
