Ana içeriğe geç
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: adım 1, 1 resimden 1.
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 2, 2 resimden 2.
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 4, 1 resimden 1.
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 5, 1 resimden 1.
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 6, 2 resimden 2.
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: adım 7, 2 resimden 2.
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Ammar Dodin
1.057 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G3
4 Üyeler
3 Yorum
Clear and easy - thanks!
Beth Pierce - Yanıt
Easy breezy.
danlord65 - Yanıt
Very good and to the point
al_stewart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 9,765
