Ana içeriğe geç
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: adım 1, 1 resimden 1.
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 2, 3 resimden 3.
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 3, 2 resimden 2.
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: adım 5, 3 resimden 3.
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ammar Dodin
1.057 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 5,120
