Ana içeriğe geç
Lenovo IdeaPad 300-17ISK RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: adım 1, 1 resimden 1.
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 300-17ISK RAM Replacement: adım 2, 2 resimden 2.
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: adım 3, 1 resimden 1.
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad 300-17ISK RAM Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad 300-17ISK RAM Replacement: adım 4, 3 resimden 3.
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
Sonuç
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ammar Dodin
1.057 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 2,456
