Giriş
You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
Neye ihtiyacın var
Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
