Ana içeriğe geç
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: adım 1, 1 resimden 1.
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: adım 2, 2 resimden 2.
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: adım 3, 1 resimden 1.
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: adım 4, 1 resimden 1.
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: adım 5, 1 resimden 1.
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: adım 6, 1 resimden 1.
    • Gently remove the WLAN card out of its slot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ammar Dodin
1.057 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G3
4 Üyeler
3 Yorum
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - Yanıt
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 2,798
