Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Replace the battery of your Lenovo IdeaPad 310 Touch-15ISK. This simple guide will describe how to access and remove the internal battery for replacement. The battery is fairly buried within the computer so the removal of major components is required.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the laptop over and remove the 13 Phillips #1 screws from the bottom panel. Remove the 2 Phillips #1 screws holding RAM panel in and then remove RAM panel
    • Flip the laptop over and remove the 13 Phillips #1 screws from the bottom panel.
    • Remove the 2 Phillips #1 screws holding RAM panel in and then remove RAM panel
  2. Disconnect keyboard and touchpad wire using a soft pry bar. Remove CD port.
    • Disconnect keyboard and touchpad wire using a soft pry bar.
    • Remove CD port.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Flip laptop back over. Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  5. Remove the 4 Phillips #0 screws holding the motherboard to the computer. Disconnect the fan tab on the bottom of the motherboard. Remove the 5 tabs holding the motherboard to the computer and remove the motherboard.
    • Remove the 4 Phillips #0 screws holding the motherboard to the computer.
    • Disconnect the fan tab on the bottom of the motherboard.
    • Remove the 5 tabs holding the motherboard to the computer and remove the motherboard.
  6. Unscrew the 2 Phillips #0 screws holding the battery in place. Remove wire tab holding battery in place.
    • Unscrew the 2 Phillips #0 screws holding the battery in place.
    • Remove wire tab holding battery in place.
    • Carefully remove battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cam Plute
201 İtibar
1 Kılavuz yazıldı
Takım
4 Yorum
Step 2 should include removing connectors for the wireless card.
Ronn Richardson - Yanıt
Thanks for your commentary, I have added this in my French translation but I don’t know why I can’t modify the tutorial in English.. Maybe because I am a French member..
Zacharie Troletti-Gillot -
The fan should also be disconnected in step 2 not step 4.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 64
Son 30 gün: 333
Her zaman: 13,016
