Ana içeriğe geç
Lenovo IdeaPad 5 15ITL05 Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 2.
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: adım 2, 3 resimden 1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: adım 2, 3 resimden 2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: adım 2, 3 resimden 3.
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: adım 3, 2 resimden 1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: adım 3, 2 resimden 2.
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: adım 4, 2 resimden 1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: adım 4, 2 resimden 2.
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the battery: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 6 Remove the battery: adım 6, 1 resimden 1.
    • Remove the battery.
Sonuç
E N
422 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 78
Her zaman: 409
