Ana içeriğe geç
Lenovo IdeaPad 720S-13IKB CPU Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove back cover: adım 1, 1 resimden 1.
    • Power off Device
    • Remove charger
    • Remove 6 T5 Screws
    • Remove 4 T5 Screws (These Screws are at an angle)
    • Remove the back cover using opening Pics. Start at the back(where the screen is)
  2. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: adım 2, 1 resimden 1.
    • SSD/DisplayConnector Cover
    • Battery
    • M.2 Wifi&Bluetooth
    • Speakers
    • RAM Cover
    • CPU
  3. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Battery: adım 3, 1 resimden 1.
    • Unplug battery
    • Remove all 3 Screws using PH1
    • Take out the battery
  4. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: adım 4, 1 resimden 1.
    • Fingerprint reader
    • Touchpad
  5. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Covers: adım 5, 2 resimden 1. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Covers: adım 5, 2 resimden 2.
    • Remove Screws with PH1
    • Remove Screws with PH0
    • Remove RAM cover
    • All covers are also secured using contact clips (Picture 2). Just pull them out
  6. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: adım 6, 1 resimden 1.
    • DRAM (K4aag165wb MCRC)
    • Connector To Display
    • M.2 SSD
  7. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Speaker: adım 7, 1 resimden 1.
    • Unplug Fans
    • Disconnect Fingerprint and Touchpad
    • Take out Speakers
  8. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Motherboard: adım 8, 2 resimden 1. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Motherboard: adım 8, 2 resimden 2.
    • Remove screws using PH0
    • Remove screws using PH1 and take m.2 parts out
    • Dissconnect cables
    • Disconnect Display Cable
    • No Idea how to connect Display Cable (Tips welcome)
    • Push Moterboard to the left and take it out.
    • At the USB-A Port is some cushion to keep the Motherboard in place.
    • follow Teardown till covers are removed (Step 5)
  9. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: adım 10, 1 resimden 1.
    • Disconnect fan cable
    • Unscrew using PH1
    • Take Fan Out
Sonuç
Hinomi
325 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 12
