Ana içeriğe geç
Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Battery: adım 1, 1 resimden 1.
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 2, 1 resimden 1.
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 3, 1 resimden 1.
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 4, 2 resimden 2.
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 5, 1 resimden 1.
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Fan: adım 6, 1 resimden 1.
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 7, 1 resimden 1.
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 8, 1 resimden 1.
    • Now the fan is completely removed.
  9. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Touchpad: adım 9, 1 resimden 1.
    • After battery is removed, you will move to the touchpad.
  10. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 10, 1 resimden 1.
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  11. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 11, 2 resimden 1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 11, 2 resimden 2.
    • Remove all the screws holding the touchpad down.
  12. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Circut Board: adım 12, 1 resimden 1.
    • Once fan and battery are removed, you are finally able to fully access the circuit board.
  13. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 13, 2 resimden 1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 13, 2 resimden 2.
    • Disconnect the touchpad cord from the circuit board using a nylon spudger.
  14. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 14, 1 resimden 1.
    • Then you will lift up the flap that holds these wires down.
  15. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 15, 3 resimden 1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 15, 3 resimden 2. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 15, 3 resimden 3.
    • After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
  16. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 16, 1 resimden 1.
    • After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
  17. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: adım 17, 1 resimden 1.
    • The circuit board is completely removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 843
