Ana içeriğe geç
Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Battery: adım 1, 1 resimden 1.
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 2, 1 resimden 1.
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 3, 1 resimden 1.
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 4, 2 resimden 2.
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 5, 1 resimden 1.
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Touchpad: adım 6, 1 resimden 1.
    • After battery is removed, you will move to the touchpad.
  7. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 7, 1 resimden 1.
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: adım 8, 2 resimden 2.
    • Remove all the screws holding the touchpad down.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 553
