Ana içeriğe geç
Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 2 resimden 1. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 2 resimden 2.
    • Remove one 5mm screw.
  7. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Flex 4-1130 Wi-Fi Card Replacement: adım 7, 2 resimden 2.
    • Remove the Wi-Fi card from the motherboard socket.
Sonuç
Adrian Miranda
677 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 346
