Ana içeriğe geç
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 2, 2 resimden 2.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: adım 3, 1 resimden 1.
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 4, 1 resimden 1.
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 5, 2 resimden 2.
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: adım 6, 1 resimden 1.
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elijah Ellis
616 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G2
3 Üyeler
Bir Yorum
Does this procedure reset the BIOS?
Mark Webb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,562
