Giriş
This guide will help you to replace your CMOS battery; sized similarly to a watch battery, this powers the laptop's real-time clock, and when it fails your computer may have difficulty 'remembering' its hardware settings, causing issues with day-to-day use.
Neye ihtiyacın var
Remove the eight 6 mm screws using a Phillips #0 screwdriver.
Remove the two 11 mm screws using a Phillips #0 screwdriver.
Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
Remove the cover.
2 farklı kişi bu kılavuzu tamamladı.
