Ana içeriğe geç
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Demario Robinson
1.038 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G6
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,622
