Ana içeriğe geç
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: adım 6, 1 resimden 1.
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 8, 1 resimden 1.
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elijah Ellis
616 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,274
