Ana içeriğe geç
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: adım 2, 2 resimden 2.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Demario Robinson
1.038 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G6
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
can someone please tell me where to find the back cover? i need to order it
angel etoile - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 71
Her zaman: 19,166
