Ana içeriğe geç
Lenovo IdeaPad Flex 5 14ARE05 Display Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 2, 3 resimden 3.
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 3, 1 resimden 1.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Battery: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 5, 2 resimden 2.
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Cooling Fan: adım 6, 1 resimden 1.
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 7, 3 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 7, 3 resimden 2. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 7, 3 resimden 3.
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
  8. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Display: adım 8, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement, Display: adım 8, 2 resimden 2.
    • Disconnect the two connectors connected to the display.
    • Be careful not to break any of the wires or connectors.
  9. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 9, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Display Replacement: adım 9, 2 resimden 2.
    • Remove the three 2 mm screws from the left hinge using a Phillips #2 screwdriver.
    • Remove the two 2 mm screws from the right hinge using a Phillips #2 screwdriver.
    • Bend the metal brackets, lift the hinges off the frame, and remove the display.
Sonuç
Jaynilson
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Konn Fall 2024 UMass Dartmouth, Team 1-6, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 34
Son 30 gün: 86
Her zaman: 250
