Ana içeriğe geç
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: adım 3, 1 resimden 1.
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 406
