Ana içeriğe geç
Lenovo IdeaPad Flex 5-1470 RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1470 RAM Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 RAM Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 RAM Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Use a spudger to gently bend down the locking tabs on the RAM casing.
  4. Lenovo IdeaPad Flex 5-1470 RAM Replacement: adım 4, 1 resimden 1.
    • Use a spudger to gently lift the RAM casing, then lift it up and off.
  5. Lenovo IdeaPad Flex 5-1470 RAM Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 RAM Replacement: adım 5, 2 resimden 2.
    • Gently take hold of the RAM card and lift slightly.
    • Pull the RAM card directly out of its port.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 564
