Ana içeriğe geç
Lenovo IdeaPad Flex 5-1470 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 4, 2 resimden 2.
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: adım 6, 2 resimden 2.
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
Sonuç
Ryan Beste
141 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, White Winter 2020 Cal Poly, Team S2-G5, White Winter 2020 üyesi
CPSU-WHITE-W20S2G5
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,122
