Ana içeriğe geç
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: adım 1, 1 resimden 1.
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 4, 2 resimden 2.
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: adım 5, 3 resimden 3.
    • Remove the RAM from its slot on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Thank you so much
Ayham Ka - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 62
Her zaman: 1,118
