Giriş
This guide will walk you through the steps of removing the SSD card. The SSD card is essential to the Lenovo IdeaPad Flex 6-14IKB because it allows for the laptop to obtain storage and the memory of the device.
Neye ihtiyacın var
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
