Ana içeriğe geç
Lenovo IdeaPad G50-45 DVD Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: adım 1, 1 resimden 1.
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 2, 2 resimden 2.
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 3, 2 resimden 2.
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 4, 1 resimden 1.
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: adım 5, 1 resimden 1.
    • Lastly, pull out the DVD Drive; it should come out easily.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Saulo Gomes
601 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S2G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 8,470
