Ana içeriğe geç
Lenovo IdeaPad G50-45 Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: adım 2, 1 resimden 1.
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: adım 3, 1 resimden 1.
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad G50-45 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: adım 5, 1 resimden 1.
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: adım 6, 1 resimden 1.
    • The fan should be removed now and appear as so.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Robert Muir
359 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S2G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 2,961
