Ana içeriğe geç
Lenovo IdeaPad G50-45 Screen Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: adım 2, 1 resimden 1.
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: adım 3, 3 resimden 1. Lenovo IdeaPad G50-45 Screen Replacement: adım 3, 3 resimden 2. Lenovo IdeaPad G50-45 Screen Replacement: adım 3, 3 resimden 3.
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: adım 4, 1 resimden 1.
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: adım 5, 1 resimden 1.
    • Test the new screen by turning it on before putting the bezel back on.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jessy McDermott
200 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S2G6
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
The tutorial was pretty straightforward, and worked.
Remy G - Yanıt
My Laptop is got work the searen is blue it what trun on
Rebecca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 7,913
