Ana içeriğe geç
Lenovo IdeaPad N586 Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad N586 Fan Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement: adım 2, 2 resimden 2.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Fan Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Now remove the last two screws highlighted
  4. Lenovo IdeaPad N586 Fan Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement: adım 4, 2 resimden 2.
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
  5. Lenovo IdeaPad N586 Fan Replacement, Memory: adım 5, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement, Memory: adım 5, 2 resimden 2.
    • Now push the little clips out away from the memory to unlock the memory.
  6. Lenovo IdeaPad N586 Fan Replacement: adım 6, 1 resimden 1.
    • After unlocking the memory from it's position, pull the memory out.
  7. Lenovo IdeaPad N586 Fan Replacement, Keyboard: adım 7, 1 resimden 1.
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  8. Lenovo IdeaPad N586 Fan Replacement: adım 8, 1 resimden 1.
    • Slowly and gently lift the keyboard up to separate from the chassis.
  9. Lenovo IdeaPad N586 Fan Replacement: adım 9, 1 resimden 1.
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  10. Lenovo IdeaPad N586 Fan Replacement: adım 10, 1 resimden 1.
    • Now remove the keyboard from the computer.
  11. Lenovo IdeaPad N586 Fan Replacement, Fan: adım 11, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement, Fan: adım 11, 2 resimden 2.
    • Pull the plug shown.
  12. Lenovo IdeaPad N586 Fan Replacement: adım 12, 2 resimden 1. Lenovo IdeaPad N586 Fan Replacement: adım 12, 2 resimden 2.
    • Lift up fan.
    • Remove two highlighted screws.
  13. Lenovo IdeaPad N586 Fan Replacement: adım 13, 1 resimden 1.
    • This is the fan separated from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick
453 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G7
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
These instructions are incomplete. There are no steps to getting from removing the keyboard to getting to the fan. There may be more missing.
Clint Hatchett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,017
