Ana içeriğe geç
Lenovo IdeaPad N586 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad N586 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  2. Lenovo IdeaPad N586 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slowly and gently lift the keyboard up to separate from the chassis.
  3. Lenovo IdeaPad N586 Keyboard Replacement: adım 3, 1 resimden 1.
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  4. Lenovo IdeaPad N586 Keyboard Replacement: adım 4, 1 resimden 1.
    • Now remove the keyboard from the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher
676 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G7
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
Clint Hatchett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 1,838
