Ana içeriğe geç
Lenovo IdeaPad N586 Memory Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad N586 Memory Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaPad N586 Memory Replacement, Battery: adım 1, 2 resimden 2.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Memory Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad N586 Memory Replacement: adım 2, 2 resimden 2.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Memory Replacement, Back Panel: adım 3, 1 resimden 1.
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Memory Replacement: adım 4, 1 resimden 1.
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Memory Replacement, Memory: adım 5, 2 resimden 1. Lenovo IdeaPad N586 Memory Replacement, Memory: adım 5, 2 resimden 2.
    • Now push the little clips out away from the memory to unlock the memory.
  6. Lenovo IdeaPad N586 Memory Replacement: adım 6, 1 resimden 1.
    • After unlocking the memory from it's position, pull the memory out.
Sonuç
Christopher
676 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G7
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 652
