Ana içeriğe geç
Lenovo IdeaPad N586 Optical Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad N586 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaPad N586 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Optical Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad N586 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Optical Drive Replacement, Back Panel: adım 3, 1 resimden 1.
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Optical Drive Replacement: adım 4, 1 resimden 1.
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Optical Drive Replacement, Optical Drive: adım 5, 1 resimden 1.
    • Locate and remove the single screw right of the optical drive
  6. Lenovo IdeaPad N586 Optical Drive Replacement: adım 6, 1 resimden 1.
    • Optical Drive should slide out easily with one thumb's effort.
Sonuç
Christopher
676 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G7
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 354
