Giriş
Adding to or upgrading the RAM in a computer is a common way to improve its performance. This guide provides instructions on how to accomplish this.
Parçalar
Hiçbir parçaya gerek yok.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Use the spudger to separate the bottom panel from the laptop case.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Remove the two 2.5mm Phillips #0 screws marked in this picture.
    • Locate the battery connector.
    • Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip.
    • Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • There is still a live current in the battery. Use a plastic tool to pull the battery connector.
    • The battery can now be lifted from the laptop case.
    • Pull the tabs on either side of the top RAM stick outwards. The RAM stick will pop up, and can be removed.
    • As with the top stick, pull the tabs on either side of the lower stick out until it pops up, and remove it.
Sonuç
Joel Hottman
277 İtibar
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 13
Her zaman: 58
